Evp58
Jul 06, 2023Tutor
RBR40 Security Settings
I have had an RBR40 for a few years now and recently had to change my password. After I changed the password on Orbi and my 30 or so devices connected to the network, my WIFI on computer and phone s...
- Jul 07, 2023
If you used a web browser to change the RBRs web page setting, setting WPA2 only should remain.
Try using Safari or Firefox browser.
Be sure to clear out all browser caches before entering the RBRs web page at 192.168.1.1
You can leave it on mixed mode. Apple is only giving this message as they detect TPIK being seen on the signal along with AES. They prefer not to see TPIK since that's been compromised long ago and Apple doesn't want people to use it. Most there for backwards compatibility for older wifi devices.
Evp58
Jul 07, 2023Tutor
My firmware is up to date: V2.7.4.24
I use all Apple products: iMac, MacBook Air, iPhone, etc.
My router sticks with WPA/WPA2-Personal.
I assume then that this security is ok even though I am getting message "weak security"?
Thanks
Jul 07, 2023Guru - Experienced User
