TG360
May 18, 2019Aspirant
RBR40 Slow Ethernet Connection
I have been having this issue for a few months now, before it was working totally fine and I had not changed anything. It seems like every device plugged into ethernet of the router gets capped at ~8...
- May 18, 2019
TG360 wrote:
That was the device at 1000m and my PC at 100m...
That sounds like full duplex auto-negotiation has failed between Orbi and your PC. If your PC is awake, it shouldn't say 100M/Full if auto-negotiation works correctly. It could be that the cable has gone bad. Otherwise, you can try to change the PC NIC setting to force it do to 1000M/Full. If you have a Gigabit switch in between, that will tell you for sure where the issue lies.
