janfossi
Oct 30, 2020Aspirant
RBR40 Slow WAN Connection
My RBR40 is giving no more than 150Mbps on the WAN Port. I have a 400Mbps download and 200Mbps internet connection which I tested connecting my computer directly to the ethernet cable with similar s...
janfossi
FURRYe38 The firmware version is V2.5.1.22.
It's connected to a ZNID-GPON-2425A-0GT (Zhone Technologies)
Oct 30, 2020Guru - Experienced User
Check the speed with a wired PC at the ONT with out the RBR connected.
Be sure your using a good quality LAN cable between the ONT and RBR. CAT6 is recommended.
Power OFF both ONT and RBR for 30 seconds then back on.
- janfossiOct 30, 2020Aspirant
Hi FURRYe38 this is a persistent problem. I have performed reset and even make the technicians form the ISP to come to my house to check the connectivity and everything is ok. They offer me a wireless router of their own but I didn't accept it, I need to cover 3000sqft with concrete walls and they won't provide a system with repeaters. I have connected my computer directly to the ONT and the speed is 400Mbps.
I'm using CAT6. I was using CAT5e (which is also fine for 1Gbps but I changed it anyway a couple of weeks ago).
I have actually updated to the latest version for the RBR40 this morning and the behaviour was as follows:
- It restarted. When the wifi kick-in I connected with my laptop via WIFI and it reached 380Mbps... Great! But after maybe 2 - 3 minutes it came back to 150Mbps on the WAN side of the RBR40 again (measured with the SpeedTest app included on the router). It seems that when the RBS40 (Satellites) start connecting, it decreases the speed on the WAN. It's really annoying, this is a very expensive system.
- FURRYe38Oct 30, 2020Guru - Experienced User
So a reset on the Orbi system has been performed and setup from scratch?
Is Armor or Circle enabled?
Try this, leave OFF the RBS for a while. Reboot the ONT and RBR. Test the speed initially then after a while. Does the speed reduce still or maintain?
