cmaustin
Aug 05, 2020Aspirant
RBR40 slow wifi
Hello, I have the RBR40 and the two wall plug satellites that came with it. System has work great for over a year. In the past few weeks, the wifi speeed slowed to a crawl. I was about 300mbps down, ...
Aug 05, 2020Guru - Experienced User
Has the system been powered OFF for 1 minute then back on?
- cmaustinAug 05, 2020Aspirant
Orbi Firmware: Router V2.5.1.16 Satellite: V2.5.0.4
Spectrum Internet Box: Hitron E31N2V1
1 min off reboot: Yes
Channel: Auto
3850 sq ft home. Sats are about 30 feet from the router.
I have not tried differnt channels. Is that my only hope to fix?
- FURRYe38Aug 05, 2020Guru - Experienced User
Are the sats RBS or RBWs?
- MstrbigAug 05, 2020Master
The sats that usually come with the RBR40 are RBW30.
I'm thinking he has new WIFI systems in his area and maybe has interference.
I know I recently had to change my 2.4Ghz channel because me installing a mesh system in my neighbor's home.
