cmaustin
Aug 05, 2020Aspirant
RBR40 slow wifi
Hello, I have the RBR40 and the two wall plug satellites that came with it. System has work great for over a year. In the past few weeks, the wifi speeed slowed to a crawl. I was about 300mbps down, ...
cmaustin
Aug 13, 2020Aspirant
I already have 2.5.16 on my RBR40. My sats are RBW30, not RBS40. Im theorizing that firmware V2.5.0.4 on my RBW30s started all my problems.
Aug 13, 2020Guru - Experienced User
What was last working version of FW on the RBWs?
cmaustin wrote:I already have 2.5.16 on my RBR40. My sats are RBW30, not RBS40. Im theorizing that firmware V2.5.0.4 on my RBW30s started all my problems.
- cmaustinAug 13, 2020Aspirant
I'm not sure. I didnt write down the version. I just updated when the UI say a new firmware is available.
- FURRYe38Aug 13, 2020Guru - Experienced User
You might try to roll them back to last version posted on NGs web site and see if anything changes. I would push the udpate thru the RBWs web page and then factory reset them and then re-add them.
cmaustin wrote:I'm not sure. I didnt write down the version. I just updated when the UI say a new firmware is available.
How do you access the RBWs web page?
They should have an associated IP address listed on the RBRs web page. Use this IP address in a web browser to access the RBWs web page.
This didnt work. The Sats just say the firmware failed to upload. Any other ideas?
- FURRYe38Aug 14, 2020Guru - Experienced User
I would make contact with NG support on this...
- cmaustinAug 15, 2020Aspirant
Thanks for all your help. I just think I have an outdated system and Netgear hasnt fully tested their firmware updates with my system. Its odd, my iphone will get 10 down, .4 up, I wont move, reboot the Orbi via the app, once the phone reconnects, super fast. Wait a while, slow again. I disappointed in Netgear for pushing an update (only thing that changed), that I cant roll back and makes my wifi unstable.
I would call support, but looks like I have to pay. Hmmm
- FURRYe38Aug 15, 2020Guru - Experienced User
Can contact a forum moderator to see what your options are.
Seems like you should be able to downgrade the FW though... :smileyfrustrated:
