MMSOOD
Dec 08, 2019Follower
RBR40 stopped working with Wi-Fi calling
I have Google Fi phone service and use wi-fi calling when at home. In fact, I use wifi for everything on that phone while at home. Text works ok Data works ok Incoming call work ok Outgoing ca...
Dec 09, 2019Guru - Experienced User
Try enabling Beamforming, SIP ALG, and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
