Fia
Jun 02, 2021Follower
RBR40 stopped working
My Orbi RBR40 router stopped working yesterday and it does not help to reset or reinstall. The ethernet cabel works fine when inserted direct to the computer, so the problem should be the router. Wh...
Jun 02, 2021Guru - Experienced User
Pressing the reset button for 15 seconds then release, do you see the top ring LED blink then slowly pulsate WHITE? After that, can you access the RBRs web page at 192.168.1.1?
