bgladden43
Nov 16, 2020Aspirant
RBR40 to ATT Fiber using Arris BGW210
I have read several threads on setting this up. First, do not trust your ATT installer. They said to just plug in the Orbi like I did with Xfimity and it will work fine, not true. What is the best set...
bgladden43
Thanks Furrye38.
Curious on why 3 options versus one. I’ve read the IP Passthrough Lolita the number of devices. I’m not technical so easiest one to setup that will work in a home/multiple devices setup. Thanks
Nov 16, 2020Guru - Experienced User
Option #3 will be the easiest....
