Cicloforza
Mar 15, 2020Guide
RBR40 Unable to update firmware to 2.3.5.34
For RBR40, have tried to update from 2.3.5.30 to .34 via mobile and manually. Mobile returns error that no update available, while Explorer give error that disk file is corrupted. Any solution plea...
- Mar 16, 2020
PLEASE DO NOT OPEN THE .IMG files. You have to apply them in the RBR web page with a web browser on a PC or laptop. YOu have to log into the RBRs web page and use the FW update feature there to apply the IMG file. They are processed and used by the RBR or RBS web page only. They can't be opened.
Retired_Member
Mar 15, 2020
Cicloforza wrote:For RBR40, have tried to update from 2.3.5.30 to .34 via mobile and manually. Mobile returns error that no update available, while Explorer give error that disk file is corrupted.
Any solution please - thanks.
Why do you want to update?
does your system have problems?
