rahuldba
Sep 21, 2021Aspirant
Rbr40 wifi slow
I have rbr40 orbi. Firmware 2.7.3.22. When I connect lan cable to modem the speed is 400+ mbps. When I check speed in orbi app the max speed it takes is only around 90mbs. What could be the problem ...
rahuldba
Sep 22, 2021Aspirant
Modem is actiontec t3200.
I don't have armor or any other features enabled on rbr40.
The modem does give speed of 400mbps when connected to laptop using network cable. So does the model # matter much in this case ?
Sep 22, 2021Guru - Experienced User
What mode is your modem working in? Bridge or Router mode?
This modem already has a built in router:
https://www.actiontec.com/products/wifi-routers-gateways/vdsl/t3200/
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- rahuldbaSep 23, 2021Aspirant
Thank you so much for your inputs/advise.
But the steps you mentioned are very technical (not sure if i can do it myself) and you suggesting also needs assistance from my ISP provider.
ISP provider will not help much as the wifi doesn't belong to them. I did reach out to them but they wont help.
- FURRYe38Sep 23, 2021Guru - Experienced User
I would contact the ISP and ask them to help you with the actiontec t3200 as I believe this belongs to the ISP, unless you bought it 2nd hand. The ISP can and should help you with this model modem. They should be able to disable the WiFi Radios at least for you.
