Bernarusan
May 01, 2020Aspirant
RBR40 will no connect to Internet
My Orbi RBR40 suddenly stopped working. No internet. I checked the modem and actually had to go back to using the modem in order to have Internet, even if only in certain parts of my home. I tried re...
- May 02, 2020
Try a power OFF of the isp modem for 1 minute then back on. Factory reset the RBR and walk thru the setup wizard with a wired PC. See if it reconnects to the modem.
Yes you can.
May 02, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-c
Bernarusan
May 02, 2020Aspirant
Firmware is V2.3.5.32. Modem is Alcatel Lucent I-240-WR. The thing is that my setup is been working fine for a couple of years, until the RBR40 simply stopped receiving Internet. The modem is a very simple modem and has no router function, and the RBR40 I believe has no modem function.
Do you know if I can use a new RBK40 with my current 3 satellites RBS20?
- FURRYe38May 02, 2020Guru - Experienced User
Yes you can.
