Bernarusan's avatar
Bernarusan
RBR40 will no connect to Internet
My Orbi RBR40 suddenly stopped working. No internet. I checked the modem and actually had to go back to using the modem in order to have Internet, even if only in certain parts of my home. I tried re...
  • FURRYe38's avatar
    Try a power OFF of the isp modem for 1 minute then back on. Factory reset the RBR and walk thru the setup wizard with a wired PC. See if it reconnects to the modem.
    Yes you can.
