Sassytam
Sep 16, 2019Aspirant
RBR40 will not allow streaming Xfinity
I recently purchased the RBS40 will not allow me to stream Xfinity from my Roku Stick. It will also not allow me to access ESPN app on my IPhone and other websites from my Iphone. I would like to c...
Sassytam
So I have a NETGEAR Modem - CM1105v Nighthawk cable voice modem. No built in router, just modem. Firmware 2.3 .5.30 for the Orbi.
Sep 16, 2019Guru - Experienced User
Ok, thank you for letting us know about the modem.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
