GCouturier
Oct 14, 2018Aspirant
RBR40 will not update
Seems like Netgear doesnt want to recognize this device fully as a legetimate device. I cant select it under the "model" field in this "Start a new Discussion" page, and it's also not directly listed...
- Oct 14, 2018
Since your router unit is on a first release version of FW, you need to update using a middle released FW then upgrade to v210. I ran into this issue earlier this year with my friends 50 series I set up for him. I could not upgrade the router to most currect for some reason. I loaded a middle version, something in between the first released FW and the most current. That worked. Once the router was upgraded to this middle dated version, then the most current version of FW took and the router installed it.
Try loading Version 1.12.0.20 or Version 2.1.1.12 on to the router:
https://www.netgear.com/support/product/RBK40.aspx#download
If you can get these to load, then update to v.210.
NOTE:
If you update to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Oct 14, 2018Guru - Experienced User
NOTE:
- GCouturierOct 16, 2018Aspirant
Sorry it took so long to get back.. but yes it worked. I went to 1.12.0.20 first. After it auto rebooted.. I waited for maybe 5 minutes and had a difficult time reestablishing my link back into it.. ti would connect but then I wouldnt see the sattelite or whatever.. so... about 2 more minutes and I gave up waiting.. I powered the Orbi off manually and rebooted it. after 5 minutes it was stable on that last 1.x code and I could see the sattelite. I saw it said the 2.2.1.210 was the latest so I used the "update all" button. it downloaded it.. applied it and again within 5 min I was fully updated. As far as daisy chaining is concerned.. I only have 1 sattelite so I dont think it makes much difference right now. but thanks.
- FURRYe38Oct 17, 2018Guru - Experienced User
Just make sure Daisy chain is check marked. It's operation is not working on this version of FW.
Enjoy.
