ThisJRP
Nov 05, 2023Aspirant
RBR40 wired internet working but wi-fi internet not
My ISP modem is working and any device wired through my RBR40 router works, but internet over wi-fi keeps dropping. This is a new issue to me - my router has worked perfectly for years and nothing has...
ThisJRP
It's an RBR40 router. Wifi is perfect and everything is connected but there is no internet. Anything hardwired to the router has internet. I've powered on/off, rebooted and reset several times over the last few days. Wondering if there is something I can do other than buy a new mesh.
michaelkenward
Nov 05, 2023Guru - Experienced User
You missed the question about the modem in front of the router.
What connects the RBR40 to the Internet?
- ThisJRPNov 05, 2023AspirantCable modem from ISP hardwired direct to the RBR40.
- michaelkenwardNov 05, 2023Guru - Experienced User
ThisJRP wrote:
Cable modem from ISP hardwired direct to the RBR40.Please read and reply to the questions.
What is that modem? Make and model?
Your answer can narrow down the issue and rule out various possibilities.
There are hundreds of modems out there that ISPs can provide.
- ThisJRPNov 05, 2023AspirantSorry...Arris model TM1602A
