BPearce
Feb 10, 2020Guide
RBR40 with 2.4.18.6 Hue and Apple issues
Recent issues with Phillips Hue and Apple home app...
1) My connection to my hue bridge works on one orbi satellite but if I move to another the connection is lost.
2) Quite frequently now the Apple Home app is stuck "Loading Accessories and Scenes"
After some solid performance from the orbi system for quite sometime these issues have arose recently. I have the RBR40 with 2 RBS40's with firmware V2.3.5.30
Sort By
- BPearceGuide
Corrected firmware version in subject title
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
I recenlty had issues with Hue Bridge also after a long time of no issue, I wonder if it had an update.
I moved the Hue Bridge from a RBS50 connection to the RBR50, no more lost connections to lights for days now.
The Bridge was far from the lights not responsive, but the lights themselves communicate with each other for connecting I understand, so I'm not sure what was going on.
No other device connected to the RBS50 has encountered any issues.
So what I'm getting at here is, move the Hue bridge!
- BPearceGuideI started with hue support and they had mentioned they had some security updates recently that had affected bridges that were attached to extenders. Moved mine to a wired connection to orbi router but didn’t fix the problem I had connecting to bridge with hue app.
Please give feedback to the questions presented.
