BANsOnLn
Sep 22, 2019Guide
RBR40 with 3 RBS20 and 1 RBW30 2,4ghz devices connection issues
I have a 4500sq (3 floors) house built in 1998. I have had issues with my Asus router ever since we moved in with connectivty issues throughout the entire house. I purchased the Netgear Orbi Mesh sys...
BANsOnLn
Sep 30, 2019Guide
I am returning these and am going to give the RBK53 a try. No matter what I do with the settings my wifi cameras will work for a short time and then drop connections. We can't use wifi calling at all as the connection is so bad. If the RBK53 does not work then I will give Linksys Velop a try.
Sep 30, 2019Guru - Experienced User
Please try some of the suggestions as well as mentioned.
Please also give feedback to the questions presented so we can get an better idea of whats going on.
BANsOnLn wrote:I am returning these and am going to give the RBK53 a try. No matter what I do with the settings my wifi cameras will work for a short time and then drop connections. We can't use wifi calling at all as the connection is so bad. If the RBK53 does not work then I will give Linksys Velop a try.
- BANsOnLnSep 30, 2019Guide
I appreciate all the advice given on this post and I can assure you I have tried them all. Nothing seems to be consisent. Just when I think I have it working, an hour later it stops and then I am back to square one.
- FURRYe38Sep 30, 2019Guru - Experienced User
We still know know about the questions presented.
It's possible you have a faulty system as well. See if the 50 series systems works better. Please keep the distance of the RBR and RBS in mind.
Good Luck.- BANsOnLnOct 01, 2019Guide
as far as distance goes, if the console is showing a "good" connection between the main and the satellites is that ok?
