HarpandDiesel
Apr 01, 2020Aspirant
RBR40 with no link light
My Orbi has worked pretty well since purchase but all of a sudden it stopped. I noticed there is no longer a link light when I plug it in to the cable modem. Checked the modem port and the cable. T...
HarpandDiesel
Thank you for that, FURRYe38 At least I am getting a link light now, though it is amber (not green) and the Orbi still is flashing white. Tried unplugging and resetting.
When I hard wire it to my Mac, it sees that address as unreachable.
Apr 02, 2020Guru - Experienced User
Sounds like the RBR is not functional any more.
You can try a recovery to see if you can get the RBR working:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
https://github.com/jclehner/nmrpflash
If this fails, please open up a support ticket and ask for help and information on what is needed next. Ask if a RMA is an option
https://www.netgear.com/support/#
Good Luck.
