Srb22's avatar
Srb22
Tutor
Dec 07, 2022
RBR40 with RBW30 - Options to expand system instead of replacing it?
Hi, Having expanded our house I now find dead zones and need additional satellites to cover these areas.  I also added. google camera and spotlight outdoors which is out of wifi range.  What I want ...
  • plemans's avatar
    Dec 07, 2022
    The AC units were much more compatible than the newer AX.
    Your RBR40 system will work will all those listed even version 1 and 2 devices.
    so not much to worry about there. The only issue sometimes seen is the outdoor version has an extender mode and an Orbi mode. by default it should come in orbi mode but you occasionally see it where someone has to switch it. Easy to do.
    In terms of adding them, I usually just tell people to do their best to centrally locate their router. Daisy chain can cause slow downs and is only recommended for 2 satellites.
    Daisy chain: router---->satellite----->satellite
    Star:  satellite<------router------>satellite.
    You can daisy chain more but you start seeing slow downs/latency issues.
    Amount of satellites?
    The AC units officially support up to 6 but i've seen more. So you're 3x satellites should be fine.
    https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
