Srb22
Dec 07, 2022Tutor
RBR40 with RBW30 - Options to expand system instead of replacing it?
Hi, Having expanded our house I now find dead zones and need additional satellites to cover these areas. I also added. google camera and spotlight outdoors which is out of wifi range. What I want ...
- Dec 07, 2022
The AC units were much more compatible than the newer AX.
Your RBR40 system will work will all those listed even version 1 and 2 devices.
so not much to worry about there. The only issue sometimes seen is the outdoor version has an extender mode and an Orbi mode. by default it should come in orbi mode but you occasionally see it where someone has to switch it. Easy to do.
In terms of adding them, I usually just tell people to do their best to centrally locate their router. Daisy chain can cause slow downs and is only recommended for 2 satellites.
Daisy chain: router---->satellite----->satellite
Star: satellite<------router------>satellite.
You can daisy chain more but you start seeing slow downs/latency issues.
Amount of satellites?
The AC units officially support up to 6 but i've seen more. So you're 3x satellites should be fine.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
Dec 07, 2022Guru - Experienced User
You can add the following:
RBS20, RBW30, RBS40, RBS40V (voice), RBS50, RBS50Y (outdoor)
Quite a few options for what you'd like to add.
I've also seen people use standard satellites and use weatherproof enclosures (that have some venting to prevent overheating in summer)
Srb22
Dec 07, 2022Tutor
Thanks for this - one follow-up: Assuming I can source 1 additional RBW30 (or a satellite of any kind) and also 1 RBS50Y unit:
- Do I need to be cautious of interoperability with what is available on the market today with my existing equipment vintage? And,
- Are there any gotchas I need to be aware of adding these 2 devices to my system that was originally just the router and wall plug satellite?
I haven't found anything definitive in terms of the max number of satellites / extenders I can add on this pair, or what compatibility limitations there are - any insight you have is appreciate so I dont source something I cannot make work
Much appreciated!
- plemansDec 07, 2022Guru - Experienced User
