luigibr
Jun 23, 2020Aspirant
RBR40 x FVS318G x URL Filtering
Good evening, I would like to add firewall and url filtering to my network (for example: I want to block some youtube channels (https://www.youtube.com/channel/{channelID}). While researching the Int...
luigibr
Jun 24, 2020Aspirant
Thank you for the reply CrimpOn . Do you know if OpenDNS can handle blocking partial URLs? Because I don't want to block for example youtube at all just some channels. And I have Pi-Hole installed, but it only handles the domain not partial URL. I am still planning to install Squid proxy, just need more time to understand how it works.
CrimpOn
Jun 24, 2020Guru - Experienced User
Several posts have talked about using OpenDNS, but I have not. It's the "Wild West" at my house.
