Mass2479
Apr 15, 2018Aspirant
RBR40
I have an RBR40 My first question is, Is this and older version? because I can't find this version I only see RBR50. Second question is can I connect a satellite with ethernet ports to my RBR40 and...
DarrenM
Apr 17, 2018Sr. NETGEAR Moderator
RBR40 is just smaller and covers a less sq feet than the RBR50 but everything else is the same. and yes you can use Ethernet back haul if you have any 2.1 firmware or higher on your system.
DarrenM
