Snark66
Jun 22, 2018Tutor
RBR40
My ORBI has dropped both my satellite extenders around the time of the last firmware update. How can I reconnect? My app says they are "unknown" so it evidently knows they are there.
- Jun 25, 2018
Be sure the distance between the router and satellite is about 30 feet starting. Depending upon building materials.
Check the user manual for top LED meanings. Pink is usually a problem of the router not getting internet from your ISP service/modem.
Enjoy. :smileywink:
Jun 22, 2018Guru - Experienced User
Were the satellites updates as well when the ruoter was updated? Satellites need to be at same version.
Try a reset on one satellite, press in the reset button in back until the top led changes to amber. Then let go. Wait for the top led to slowly pulse WHITE, then re-add the satellite to the router.
Snark66
Jun 22, 2018Tutor
Sounds good, what if it's pulsing Amber?
