Snark66
Jun 22, 2018Tutor
RBR40
My ORBI has dropped both my satellite extenders around the time of the last firmware update. How can I reconnect? My app says they are "unknown" so it evidently knows they are there.
- Jun 25, 2018
Be sure the distance between the router and satellite is about 30 feet starting. Depending upon building materials.
Check the user manual for top LED meanings. Pink is usually a problem of the router not getting internet from your ISP service/modem.
Enjoy. :smileywink:
Snark66
Jun 22, 2018Tutor
You really don't realise how far out of my comfort zone i am with this..... Are you now talking about the master unit? Should I "reset" the second slave first? And PLEASE, where can I find out some of this sh1t for myself?
Jun 22, 2018Guru - Experienced User
Just reset 1 of the satellites and re-add it to see if it will reconnect.
You can look at the user manual starting on page 131:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
