Snark66
Jun 22, 2018Tutor
RBR40
My ORBI has dropped both my satellite extenders around the time of the last firmware update. How can I reconnect? My app says they are "unknown" so it evidently knows they are there.
- Jun 25, 2018
Be sure the distance between the router and satellite is about 30 feet starting. Depending upon building materials.
Check the user manual for top LED meanings. Pink is usually a problem of the router not getting internet from your ISP service/modem.
Enjoy. :smileywink:
Jun 25, 2018Guru - Experienced User
Enjoy. :smileywink:
Snark66
Jun 25, 2018Tutor
They are certainly within the 30' distsance. I pushed all the wires into all the sockets at both ends so it is possible that one of them was making a poor contact. It doesn't explain why it drops off the satellites though.
