Dangme's avatar
Dangme
Follower
Sep 22, 2018
RBR40
My Orbi RBR40 has been intermittently disconnecting from the internet. I ended up doing a reset. But I now cannot even connect to the internet to complete setup.
Firmware is up to date. Using with a Netgear CM1000 cable modem. Direct connect from modem bypassing the Orbi connects okay.
Any suggestions?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Did you reboot the whole network in the specified order?
    • Turn off and unplug the modem.
    • Turn off the modem router and computers.
    • Plug in the modem and turn it on. Wait 2 minutes.
    • Turn on the modem router and wait 2 minutes.
    • Turn on the computers.
