mizeke
Mar 23, 2019Aspirant
RBR40
I have an rbr40 with two satelite rbr30's..........I also have xfinity rented modem with voice(phone) service........Is there anything to buy from orbi that will replace xfinity modem and still have ...
- Mar 28, 2019
Xfinity supports BYOM and you can buy your own modem to use on there system. Find out what they support first before you buy.
I believe NG's CM1000/1100 series modems are supported on XF...
Mar 23, 2019Guru - Experienced User
Netgear has multiple modems with voice options available. Not specifically an orbi device but a modem/voice device.
https://www.netgear.com/home/products/networking/cable-modems-routers/CM1150V.aspx
https://www.netgear.com/home/products/networking/cable-modems-routers/CM500V.aspx
These are just 2 from doing a quick search. A little time with google would show more.
mizeke
Apr 06, 2019Aspirant
Thanks, I'll take a look.......it looks like this will work.
