Tommy50
Oct 02, 2019Follower
RBR40
CHanged wireless service. How do I get orbi to recognize the new service. Orbi is working but not connecting to the internet.
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?Cable, Fiber or DSL?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Did you power OFF the RBR and ISP modem device both for 1 minute, then back ON with the modem to let it sync then power ON the RBR? - michaelkenwardGuru - Experienced User
What does that mean? You have a new Internet service provider?
If so, you need to set up the whole network from scratch.
