mcdonaldd's avatar
mcdonaldd
Follower
Apr 02, 2020
RBR40
Just upgraded to AT &T high speed which it works when im on AT & T, but when im in a different section of my house and connected to Orbi the speeds are super slow
1 Reply
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
    Is the Orbi system operating in Router or AP mode?
    Was this happening before you changed your ISP?
