encrawford
May 05, 2021Tutor
RBR40
I have an RBR40. I recently upgraded my ISP to a gigabit service. When I connect my cable modem directly to a computer I can get download speeds of 900 Mb per second. However, as soon as I connect...
May 05, 2021Guru - Experienced User
Do you have Armor, Access Control, Circle or Traffic Meter enabled on the RBR?
encrawford
May 05, 2021Tutor
it is my modem and it is in Arris SB 8200
- encrawfordMay 05, 2021Tutor
And the Orbi firmware version is V2.5.1.22
- FURRYe38May 05, 2021Guru - Experienced User
Press the back reset button for 15 seconds then release. Set up from scratch. Power off the modem for 30 seconds then back ON. Be sure to not enable Armor, Circle, Traffic Meter or Access controls. Soon after the RBR is set up, run a quick speed test with Ooklas installable speed test app on a ethernet connected PC.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQ
What does the app report for it's results?- encrawfordMay 05, 2021Tutor
While I appreciate the reply first I'm trying to determine if the RBR40 supports gigabit speeds. According to tech support for Netgear it does not. However, they have been wrong before . Before I started trying to reconfigure my network can you point to some Netgear documentation that my router supports gigabit speeds. I have been unable to find this, this is the only information I've been able to find
https://www.netgear.com/images/datasheet/orbi/RBK40.pdf
And I don't see anywhere on that sheet that it says it supports gigabit speed.
