GSzab
May 23, 2022Aspirant
RBR40
Just did the lates firmware update and one of my satellites did not update and will not connect any advice.
- May 23, 2022
have you tried hardwiring the satellite into the router?
Then trying the update/sync?
May 23, 2022Guru - Experienced User
What version had been loaded?
How did you update the RBS? RBS should be updated first, then update the RBR lastly.
- GSzabMay 23, 2022Aspirant
Currently running V27.4.24 on the base and one satellite while the other satellite is still on the old version v7.3.22 and will not update I tried rebooting and did not work the one rbs20 will not connect . I logged on to the app this morning had a message to update firmware and clicked update.
