sidd436
Dec 27, 2022Follower
RBR40
I am attempting to send myself logs through the security tab in the router, and nothing seems to be working. I am using smtp.google.com with the correct port and authentication, and I keep getting an...
michaelkenward
Dec 28, 2022Guru - Experienced User
sidd436 wrote:
I am attempting to send myself logs through the security tab in the router, and nothing seems to be working. I am using smtp.google.com with the correct port and authentication, and I keep getting an error in the log when it attempts to send it.
Email logs from routers are a constant cause of grief. It doesn't help that email outfits keep messing around with SMTP security.
I don't know if people have had success with GMail. In my case I use Outlook.
