Mamadub54
May 25, 2024Aspirant
RBR40
I have 4 satellites connected to my RBR40. When I pull up the basic screen, it tells me all 4 satellites are working. When I pull up the network map, it only shows one connected? Are the other satelli...
CrimpOn
May 27, 2024Guru - Experienced User
Mamadub54 wrote:
I have 4 satellites connected to my RBR40. When I pull up the basic screen, it tells me all 4 satellites are working. When I pull up the network map, it only shows one connected? Are the other satellites not synced? Why are the others not showing?
Is it correct to assume that basic screen refers to the opening page of the Orbi 'app'? (and not to the web management interface) i.e. on the upper right it says "4 of 4" satellites?
Which version of the 'app' is this? (Android or Apple?)
I, personally, find the web interface more useful. Does it agree with the 'app'?
Mamadub54
May 27, 2024Aspirant
Good question, not sure, I’ll have to check. I’m using an Apple phone.
