wifiblues
Dec 27, 2020Luminary
RBR40/RBS20 specs
hi i recently upgraded my spectrum wifi service to a gig. can the RBK40 router and RBS20 satellites handle it? the specs on the box seem to indicate that it can - 866-866-400 mpbs. w...
CrimpOn
Dec 27, 2020Guru - Experienced User
wifiblues wrote:i recently upgraded my spectrum wifi service to a gig.
when checking speed test though - the results are much less. used Speedtest.net
at the same time, checking the Orbi app speed test, it shows higher numbers.
Those numbers (866-866-400) refer to the maximum theoretical connection rate over the 5G WiFi backhaul channel, the 5G user WiFi channel, and the 2.4G user WiFi channel. As the distance between devices increases, the actual "link rate" will fall. WiFi is not a "full duplex" technology where data can travel in both directions at the same time. WiFi is radio, which allows only one device to broadcast at a time. The others must "back off" and wait for that device to stop broadcasting. Two computers connected with ethernet can transmit nearly a full gigabit/sec of information between themselves, going both ways at the same time. Over WiFi, they must share that bandwidth and also lose capacity to WiFi "overhead".
Running Speedtest.net from user devices is what "counts". Reports from the Orbi itself are always higher. Computer nerds enjoy setting up capacity tests to see how much data they can push over network links. "iPerf3" is a common tool that is available for Windows, Apple, Linux, Android, etc.
The more relevant question (to me) is, "do all my devices work the way I want?" Can I stream the number of 4K video streams to my TV's, computers, etc. that I want to and have no performance problems?" If so, then Yes, this Orbi setup can handle it.
- wifibluesDec 27, 2020Luminary
hi Crimpon,
all my devices seem to work but shouldn't the router match the modem speed?
it seems that the RBK40 sits just below the gig speed capacity.
at some point, i think i should increase the router to match the modem.
what do you think?
- CrimpOnDec 27, 2020Guru - Experienced User
wifiblues wrote:hi Crimpon,
what do you think?
The router WAN port is indeed a gigabit port, so in that sense it does "match" the modem. (just my opinion, but...) Devices on the network will only bring down as much data as they need to function. If the WiFi router will process that much data, adding capacity to the router sysem will simply result in it being "more idle" than it is now. Suppose there are 8 TV's in the house live streaming video at 25mb each. That requires 200mb. Add in some web browsing, email, and a hundred smart switches sending two packets an hour and that gigabit link is essentially being less than 25% consumed. What might be noticable is sudden large downloads will complete more quickly. When I download a 60mbyte file over my 200mbit link, it may take 2-3 minutes.
hi Crimpon,
thank you!
for my very basic knowledge - can you confirm what the specs on the RBK40 means?
(866 - 866- 400 mbps) - maybe that is where my confusion lies - what do these numbers mean?
thank you,
wifiblues
