wifiblues
Dec 27, 2020Luminary
RBR40/RBS20 specs
hi i recently upgraded my spectrum wifi service to a gig. can the RBK40 router and RBS20 satellites handle it? the specs on the box seem to indicate that it can - 866-866-400 mpbs. w...
wifiblues
hi Crimpon,
thank you!
for my very basic knowledge - can you confirm what the specs on the RBK40 means?
(866 - 866- 400 mbps) - maybe that is where my confusion lies - what do these numbers mean?
thank you,
wifiblues
CrimpOn
Dec 27, 2020Guru - Experienced User
wifiblues wrote:for my very basic knowledge - can you confirm what the specs on the RBK40 means?
The product data sheet for the RBK40 shows that both the router and satellite have three WiFi radios. Using the IEEE standards for the type of signal encoding (256QAM), each of the 5G radios is supposed to be able to reach a maximum transmission of 866mb/s, and the 2.4G radio a maximum transmission rate of 400mb/s. Like most manufacturers, Netgear adds 866+866+400 and instead of getting 2,132 they call this an AC2200 (rounding UP). The footnote symbol points to the bottom of the page for the disclaimer: "† Maximum wireless signal range derived from IEEE standard 802.11 specifications. Actual data throughput and data over distance will vary. Network conditions and environmental factors, including volume of network traffic, building material and construction, and network overhead, result in lower actual data throughput rate and wireless coverage."
https://www.netgear.com/images/datasheet/orbi/RBK40.pdf
The RBS20 satellite has the same radios:
https://www.netgear.com/images/datasheet/orbi/RBS20.pdf
Google search will turn up dozens of explanations of why these "speeds" are a theoretical maximum that is never realized in practice.
For example, this piece from 2014:
- wifibluesDec 28, 2020Luminary
thank you Crimpon -
based on the spec sheet, the RBK40 should be able to handle the 1gig from Spectrum yet when i run speed tests the results do not show 1gig performance.
for example, on my laptop, not wired, the results show:
86.6 mbps download 3.85 mbps upload
on the same lap top wired to the router:
373 mbps download 5.2 mbps upload
both tests were done using the same ethernet cord and in the same room as the RBR40.
i have two concerns -
using WiFi lowers the numbers that much
if i am getting 1 gig from spectrum, should these numbers reflect that.
thanks,
wifiblues
