slkotr
Dec 06, 2017Aspirant
RBR44
Bought orbi mesh to help with wifi coverage. Having trouble with Comcast tv boxes pulling tv channels. Comcast modem set to bridge mode. Orbi router set to dynamically pull DHCP Changed ip range to...
DarrenM
Dec 08, 2017Sr. NETGEAR Moderator
You may want to use the comcast modem as a router and set the Orbi in AP mode to get the better wifi coverage.
DarrenM
- slkotrDec 09, 2017AspirantThank you for your help. I tried your suggestion and it worked. I would have preferred to set it up the other way around. But the wife is happy and her tv is working.
