mariogotze5589
Feb 13, 2017Aspirant
RBR50 – Orbi AC3000 Tri-band WiFi System
Hi I have question about this router, so this router is tri-band router ,but if you want to use the satalite with it ,it will turn this router to dual band,so if I planed to buy the router only wit...
mariogotze5589
iam planning to get a triband router because I have multiple devices, and I have a small space so no need for extension.
Do you recommend going for different models to get the full three band like ac3200, or I can use the 3 bands on this router since I'm not getting the extension?
Thanks
Thanks
loomis1975
Feb 14, 2017Luminary
Definitely go for another router for a small space. Get one that has tri-band and the features you want as a router.
