Prasenjit_mitra
Jan 18, 2025Aspirant
RBR50 — Orbi AC3000 Tri-band WiFi Router Won't Boot or Reset After Possible Firmware Update
Hello, I’m experiencing an issue with my Netgear Orbi AC3000 system (1 RBR50 Router and 1 RBS50 Satellite) and I’m hoping to get some assistance. Model: Netgear Orbi AC3000 (1 RBR50 Router and 1...
- Feb 07, 2025
Just to update, I was able to get in touch with Netgear support and since the device was under hardware warranty, they replaced it with a new unit.
Thank you all for your help!
Jan 20, 2025Guru - Experienced User
I just tried support on mine and was able to go through the "contact us" option for get support. Might retry or use a different pc
Prasenjit_mitra
Feb 07, 2025Aspirant
