BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
BillYoung
Hi FURRYe38:
To answer your questions:
Did you power OFF the ISP modem and RBR after the FW update? No.
How about a factory reset as last resort before going back? Would a factory reset really help if the firmware is the issue? I'll do it if you truly believe it would help.
Mar 16, 2021Guru - Experienced User
Lets try the power OFF of the modem and RBR for 1 minute first then back ON.
BillYoung wrote:Hi FURRYe38:
