BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
CaptainPing
Mar 16, 2021Star
Same exact issue after upgrading. At first it was just slow speed on my phone but then after that issue basically all devices in my home keep reporting no internet or internet unavailable. The only thing that seemed to alleviate the issue was putting my devices on static IP's with the gateway as DNS1 and a setting up google as DNS2. This fixed the issue but this never happened before the upgrade.
I'm going to reset it today and try again.
vajim
Mar 16, 2021Master
CaptainPing wrote:Same exact issue after upgrading. At first it was just slow speed on my phone but then after that issue basically all devices in my home keep reporting no internet or internet unavailable. The only thing that seemed to alleviate the issue was putting my devices on static IP's with the gateway as DNS1 and a setting up google as DNS2. This fixed the issue but this never happened before the upgrade.
Thanks
Let us know how your reset works.
