BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Mar 16, 2021Guru - Experienced User
Also check your NTP settings. Seeing more posts regarding this since the time change this passed weekend. Try changing from NG server to time.nist.gov or something else and test.
Let us know how the reset goes. Someome posted the reset helped them.
CaptainPing wrote:Same exact issue after upgrading. At first it was just slow speed on my phone but then after that issue basically all devices in my home keep reporting no internet or internet unavailable. The only thing that seemed to alleviate the issue was putting my devices on static IP's with the gateway as DNS1 and a setting up google as DNS2. This fixed the issue but this never happened before the upgrade.
I'm going to reset it today and try again.
CaptainPing
Mar 16, 2021Star
Why didn't I think of that! Freaking daylight savings, curse you! I'll check that setting a in a minute.
