BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Mar 16, 2021Guru - Experienced User
I had to factory reset mine as in the process of helping to find out if Circle was supported on the RBR50 in recent versions of FW, which it is, v102. So mines been reset and setup from scratch. It's been online and running well with my RBS20 for almost a month until we had a power bump this morning so that counter is reset.
I would do a full on reset and setup from scratch at some point if the power cycle doesn't work to solve this for you.
Also check out your NTP settings, change from NGs to something else. Try time.nist.gov.
BillYoung wrote:Hi FURRYe38:
Done. Everything reconnected to the Orbi and the internet after the shutdown and reboot. Is this firmware version stable enough to continue to be used? I don't want to have to keep rebooting the Orbi to resolve connectivity issues.
