BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
CaptainPing
Mar 16, 2021Star
V2.6.1.40, I did it at 6:30 est and so far so good. The issue was primarily happening on wifi devices, but since then Discord, Hearthstone, and my apps haven't had any spinning wheels or disconnect errors. I did a factory reset first and then rolled it back.
I know you can access the router via command line but I don't even know if there would be a log for issues likes this. I have no idea what was going on with the packets between my wifi devices and the router. Thank god you can roll back the firmware to an old one, a lot of electronic devices don't let you roll back without a dumb 30/30/30 procedure.
Personally I think the hardware in the Orbi is great but this is my first issue with the firmware.
I lost 5 hearthstone games because of this...who's going to get my gold stars back? : P
fredlvt
Mar 17, 2021Tutor
I am seeing the same problem. I have to reboot my RBR50 primary router 4-5 times a day to get reconnected to the internet.
Can I ask a dumb question? How do I revert to an older firmware? I usually allow Orbi to upgrade whenever I get a notification.
4 kids teaching/learning in-home, me working from home, these constant disconnects are killing us.
I agree, hardware has been a godsend to wholehouse WiFi, but this latest firmware has really changed my opinion.
- FURRYe38Mar 17, 2021Guru - Experienced User
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelliteDowngrade the RBS first then RBR lastly.
fredlvt wrote:I am seeing the same problem. I have to reboot my RBR50 primary router 4-5 times a day to get reconnected to the internet.
