BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
BillYoung
Hi FURRYe38:
To answer your questions:
Did you power OFF the ISP modem and RBR after the FW update? No.
How about a factory reset as last resort before going back? Would a factory reset really help if the firmware is the issue? I'll do it if you truly believe it would help.
bdc2021
Mar 17, 2021Initiate
Bill a factory reset will solve your problem. It did for me. Had nothing to do with the firmware. Other people have rolled back to previous firmware versions with no results. Uncheck Advanced>Administration>NTP Settings>Automatically adjust for daylight savings time
A Netgear developer introduced a Daylight Savings bug.
- GeblaMar 18, 2021Apprentice
So happy that I read this before I am getting this bug. We will have day light saving on 28/03. I therefore disabled daylight saving and changed the NTP server. hoping this will prevent taht I am getting this issue
- kinwolfMar 18, 2021Guide
Well, here I downgraded to 2.6.1 but doing so screwed the admin interface authentication so I had to do a factory reset too. So far, so good, no more problems, but I cannot say which of the two solved it. Only thing I know was that it was a HIGHLY frustrating experience.
- vajimMar 18, 2021Master
kinwolf wrote:Well, here I downgraded to 2.6.1 but doing so screwed the admin interface authentication so I had to do a factory reset too. So far, so good, no more problems, but I cannot say which of the two solved it. Only thing I know was that it was a HIGHLY frustrating experience.
what firmware did you end up on?
