BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Mar 19, 2021Guru - Experienced User
If it's working, leave it. You can try it if you like. Kind of doubt the problem will appear again. Seems like all this was when the time changed last weekend and given the few days, seems to have past. Also been reports of Traffic Meter being another cause. One user I talked with had that enabled. Disabled it and is working correctly now.
Do you use Traffic Meter any?
BillYoung wrote:
Continues to be good for me. I've noticed some people say to uncheck the Automatically Adjust for Daylight Savings Time. I haven't done that. Should I?
BillYoung
Mar 19, 2021Luminary
I have the Traffic Meter enabled. I have not used it for anything. Most of the numbers in it are 0. The only item with numbers in it is Last Month. Should I disable it?
- FURRYe38Mar 20, 2021Guru - Experienced User
Ya if you don't use it or it doesn't seem like it's working, shut it off.
I don't use it. Seems that TM seems to cause more problems than it's worth. From historical posts, it causes performance slowdowns and was recommended not to use it on 1Gb service lines. Not sure if this was ever addressed by NG.
BillYoung wrote:I have the Traffic Meter enabled. I have not used it for anything. Most of the numbers in it are 0. The only item with numbers in it is Last Month. Should I disable it?
