BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Mar 20, 2021Guru - Experienced User
Are you using DST and or Traffic Meter currently?
BAM2019 wrote:Updated to ORBI firmware 2.7.2.104 and internet dropped several times daily. Before firmware update no problems. Using Spectrum Business 1Gig internet. I rolled back to ORBI firmware V2.6.1.40 and so far no issues.
BAM2019
Mar 20, 2021Star
DST I just unchecked but the Meter is set to Auto. Should I turn off the meter? Thanks :)
- FURRYe38Mar 20, 2021Guru - Experienced User
Yesm Disable TM. Re-enable DST.
- BAM2019Mar 20, 2021Star
Ok, so ORBI firmware "V2.7.2.104" is ok as long as the Traffic Meter is unchecked (off). And just to be sure you say it is ok to check the box next to Daylight Savings Time to "Automatically adjust for daylight savings time" and this should be turned on? And I have a check next to "Use default NETGEAR NTP server" is ok too?
Again, thank you for your help :)
Yes and Yes.
BAM2019 wrote:Ok, so ORBI firmware "V2.7.2.104" is ok as long as the Traffic Meter is unchecked (off). And just to be sure you say it is ok to check the box next to Daylight Savings Time to "Automatically adjust for daylight savings time" and this should be turned on? And I have a check next to "Use default NETGEAR NTP server" is ok too?
