BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Mar 20, 2021Guru
Yesm Disable TM. Re-enable DST.
BAM2019
Mar 20, 2021Star
Ok, so ORBI firmware "V2.7.2.104" is ok as long as the Traffic Meter is unchecked (off). And just to be sure you say it is ok to check the box next to Daylight Savings Time to "Automatically adjust for daylight savings time" and this should be turned on? And I have a check next to "Use default NETGEAR NTP server" is ok too?
Again, thank you for your help :)
- FURRYe38Mar 20, 2021Guru
Yes and Yes.
BAM2019 wrote:Ok, so ORBI firmware "V2.7.2.104" is ok as long as the Traffic Meter is unchecked (off). And just to be sure you say it is ok to check the box next to Daylight Savings Time to "Automatically adjust for daylight savings time" and this should be turned on? And I have a check next to "Use default NETGEAR NTP server" is ok too?
- vajimMar 20, 2021Master
Ok, so ORBI firmware "V2.7.2.104" is ok= NO!
- BAM2019Mar 21, 2021Star
So don't update to the latest ORBI update, correct? Even with adjusting the Meter and Daylight savings date as we discussed the new update i snot ok.
- CaptainPingMar 21, 2021Star
Honestly, I thought I fixed it when I rolled back the firmware from the latest to the previous but the issues are still persistent. Until a new firmware is released, I'm done troubleshooting for now. Apparrently Netgear is already aware of the issue but its still being worked on.
