BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
WillRogersM
Mar 21, 2021Tutor
After spending an inordinate amount of time trying to go back to the former firmware, I was eventually unable to log on either with my password or with default "password". Could not access password recovery because it said my correct answers were wrong.
In this state, it worked for some devices not others. (Android worked, Apple devices not at all. Yes, rebooted everything.)
Finally did a factory reset -- unplugged base unit for 5 minutes, powered off modem, powered up the base unit while holding the "reset" button until it went from red-orange to green back to red-orange. Powered up modem. And went to the ORBI app and did a new set up using the same networks and passwords -- and eveyrthing reconnected (at least everything I've checked so far, which is lots but not all). I HAD to update to the latest. much discussed firmware so we'll see over the next few days. (Everything was fine when I first updated and then the trouble started, big time, a day later.
Worth a try.
BAM2019
Mar 21, 2021Star
I had the same issue with the passowrd and secuirty questions not working. Instead of a reset, I tried again and this time I left the security answers blank and clicked ok and then I was able to log into my ORBI Operating system and adjust the settings. Go figure!
- FURRYe38Mar 21, 2021Guru - Experienced User
Interesting. I didn't know you could leave the questions blank. Well if it works for you then, why not.
BAM2019 wrote:I had the same issue with the passowrd and secuirty questions not working. Instead of a reset, I tried again and this time I left the security answers blank and clicked ok and then I was able to log into my ORBI Operating system and adjust the settings. Go figure!
