BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
SidewinderX
Mar 21, 2021Guide
Just chiming in that I think I'm having the same issue -- started the past week (...after DST) where the router is dropping selected devices... not everything; for example the wired Roku never looses connection, nor does my work laptop (wifi+VPN), but most other laptops / cell phones are losing their connection. It comes back after I reboot, but that only lasts for a few hours to half-a-day before I have to restart the router again.
I'm trying the DST/NTP sever update now, and will disable traffic meter and hope that works.
Gebla
Mar 22, 2021Apprentice
And in the meantime the firmware is still available for download without any comments on known issues.
It seams that things like this is outside the normal service procedures and therefore ignored. The problem, as customer, is that moving to another company makes no difference as the other company will have similar processes in place.
- vajimMar 22, 2021Master
Gebla wrote:And in the meantime the firmware is still available for download without any comments on known issues.
The root of the problem is that most people interpret 'available' to mean 'must have'
sad
- GeblaMar 22, 2021Apprentice
sad
If teh only description in the release note is security fixes and the device portal highlights and recommends a firmware update is must have maybe the preferred response.
- WillRogersMMar 22, 2021Tutor
Indeed, I had been lured into a false sense of security because previous firmware upgrades had always been problem-free.
Now that I know about the community, in the future I will check this board for potential problems before I update.
However, let me emphasize that doing the factory reset, as described, was painless. Had I known how painless it would have been, I could have saved hours upon hours.
If NETGEAR cares, I have a pretty good idea what happened. They should feel free to contact me. (I know I'm listed as "Initiate" but I'm not by a long shot.)
- estegMar 31, 2021Guide
No, the root problem is effectively that this FW update is still available.
Can you imagine all people who are not on the forums and so one and can't fix this problem ???
Here is what to be done :
- removing the FW from DL list and auto update feature
- fix the bug
- quickly go for an update (DL+auto update) which will fix his lazy bug for ever.
Just a note:
- I have changed NTP : no effect, still the issue.
- I have switch off TM : no problem anymore (about 5h of fully available connexion)
The real problem is: is there any testing puprose in Netgear developper team ???
