BillYoung
Mar 16, 2021Luminary
RBR50 - 2.7.2.104 firmware - Issues?
To whom it may concern, FURRYe38: After upgrading my firmware to 2.7.2.104, I have been having issues. Devices successfully connect to the Orbi, but have no internet. If I reboot the Orbi and ...
Ursa99
Mar 28, 2021Star
I upgraded from V2.5.2.4 directly to V2.7.2.104 and had no issues after the update. I did not touch the timeserver or the traffic meter settings (which I've never changed) and did not power off the router. The update was uneventful, the two satellites connected and all 25 devices have connected properly. I am using the Orbi in AP mode with no inputs on it used except the Etherent into it from my router. I don't know if the FW is bad or not but this is my experience.
vajim
Mar 28, 2021Master
Ursa99 wrote:I upgraded from V2.5.2.4 directly to V2.7.2.104 and had no issues after the update. I did not touch the timeserver or the traffic meter settings (which I've never changed) and did not power off the router. The update was uneventful, the two satellites connected and all 25 devices have connected properly. I am using the Orbi in AP mode with no inputs on it used except the Etherent into it from my router. I don't know if the FW is bad or not but this is my experience.
How long has it been?
